ENGINE
Cooling System
♦ Engine Coolant (2.0L Engines with Single or Dual-Zone Climate Control System)
MOPAR® PARAFLU Antifreeze/Coolant 10 Year 152,000 Mile Formula OAT ( Organic Additive Technology)
MS-12106
7.7 Quarts (7.3 Liters)
♦ Engine Coolant (2.4L Engine with Single or Dual-Zone or Three-Zone Climate Control System)
MOPAR® Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology)
1 Gallon - 05066386AA
7.9 Quarts (7.5 Liters) - Engine with Single or Dual-Zone Climate Control System
9.8 Quarts (9.3 Liters) - Engine with Three-Zone Climate Control System
♦ Engine Coolant (3.6L Engines with Single or Dual-Zone Climate Control System)
14.5 Quarts (13.1 Liters)
Engine Oil with Filter
♦♦ Engine Oil (2.0L Diesel Engine)
MOBIL 1® SAE 5W-30 Low Ash Fully Synthetic oil, meeting the requirements of ACEA C2
1 Quart - 05166241AA
5.5 Quarts (5.2 Liters)
♦♦ Engine Oil (2.4L Engine)
MOPAR® API Certified SAE 5W-20 engine oil, meeting the requirements of Chrysler Group LLC Material Standard MS-6395.
1 Quart - 04761872AC, 5 Quarts - 04761851AD
4.5 Quarts (4.26 Liters)
♦♦ Engine Oil (3.6L Engine)
MOPAR® API Certified SAE 5W-30 engine oil, meeting the requirements of Chrysler Group LLC Material Standard MS-6395.
1 Quart - 04761838AB, 4 Quarts - 04761844AB
6 Quarts (5.6 Liters)
♦ System fill capacity includes heater and coolant recovery bottle filled to MAX level.
♦♦ For countries that use the ACEA European Oil Categories for Service Fill Oils, use the recommended engine oil that meets the requirements of ACEA C3, and approved to MB 229.31 or MB 229.51 only. SAE 5W-30 engine oil approved to MB 229.31 or MB 229.51 may be used when SAE 5W-20 engine oil is not available.
CAUTION:
Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
Engine Oil Filter (2.0L Diesel Engine)
MOPAR® Engine Oil Filter
68096455AA
Engine Oil Filter (2.4L Engine)
4892339AA
Engine Oil Filter (3.6L Engine)
MOPAR® Engine Oil Filter Kit
68079744AA
Fuel (approximate)
Fuel Selection (2.4L, 2.4L PZEV Engine)
87 Unleaded Octane or Higher - Domestic
20.5 Gallons (77.6 Liters)
91 Octane Premium Unleaded - Export (2.4L PZEV)
18.5 Gallons (70 Liters)
Fuel Selection (3.6L Engine)
87 Octane or higher Unleaded
20.5 Gallons (77.6 Liters) FWD
21.1 Gallons (79.8 Liters) AWD
Fuel Selection (2.0L Diesel Engines)
Use only the best quality fuel with a calculated Cetane Index of 50 or higher. In addition, the manufacturer recommends using diesel fuel with a sulfur content of less than or equal to 15 ppm.
A/C Refrigerant System
Refrigerant R-134a
82300101AB
22 Ounces (0.624 Kilograms) - Single
32 Ounces (0.907 Kilograms) - Dual
SPARK PLUGS
Spark Plugs (2.4L Engine Except PZEV)
NGK® Nickel
04606823AB (ZFR5F-11)
0.043 in (01.10 mm)
Spark Plugs (2.4L Engine PZEV)
NGK® Single Platinum
05149060AB (ZFR5AP)
0.030 in (0.80 mm)
Spark Plugs (3.6L Engine)
Champion®
SP149125AD (RER8ZWYCB4)
0.043 in (01.10 mm)
TRANSMISSIONetric
Automatic
40TE/41TE - Service Fill
MOPAR® ATF+4 Automatic Transmission Fluid
1 Quart - 05013457AA, 1 Gallon - 05013458AA
4.0 Quarts (3.8 Liters)
♦ 40TE/41TE- Overhaul Fill
1 Quart - 05013457AA, 1 Gallon - 05191185AA
9.2 Quarts (8.7 Liters)
62TE - Service Fill
♦ 62TE - Overhaul Fill
9.0 Quarts (8.5 Liters)
Manual
C635 - Service Fill
Castrol BOT - 350
1 Quart - 68092630AA, 1 Gallon - 68092636AA
1.8 Quarts (1.7 Liters)
♦ Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. Refer to the appropriate service information for the correct procedures.
CAUTION:
TRANSFER CASE
♦ Power Transfer Unit
MOPAR® Synthetic Gear & Axle Lubricant SAE 75W-90
1 Quart - 05010320AA
1.7 Pints (0.8 Liters)
♦ Approximate dry fill or fill to bottom edge of fill plug hole.
CAUTION:
CHASSIS
Axles (Rear)
♦ Rear Driveline Module
MOPAR® Gear & Axle Lubricant SAE 75W-90
1 Quart - 04874468
16.2 Ounces (0.6 Liters)
Chassis Systems
♦♦ Brake Master Cylinder
♦♦ Brake/Clutch Master Cylinder
MOPAR® Brake Fluid DOT 3, SAE J1703.
12 oz. Bottle - 04318080AB
32 oz. Bottle - 04318081AB
♦♦♦ Power Steering Reservoir
MOPAR® Power Steering Fluid +4
♦♦ If MOPAR® Brake Fluid DOT 3 is not available, then MOPAR® Brake and Clutch Fluid DOT 4 (P/N 04549625AC), is acceptable.
♦♦♦ If MOPAR® Power Steering Fluid +4 is not available, then MOPAR® ATF +4 Automatic Transmission Fluid (P/N 05166226AA), is acceptable.
CAUTION:
